Unigine::NodeReference Class
Header: #include <UnigineNodes.h>
Inherits from: Node
Read More
NodeReference Class
Members
static NodeReferencePtr create ( const char * name ) #
Constructor. Creates a new object that references a node from a given file.
Arguments
  • const char * name - Path to a *.node file.
void setNodePath ( const char * name ) #
Sets a reference to a new *.node file.
// create an NodeReference instance
NodeReferencePtr nodeRef = NodeReference::create("unigine_project/nodes/reference_0.node");
// change a reference node
nodeRef->setNodePath("unigine_project/nodes/reference_1.node");
Arguments
const char * getNodePath ( ) #
Returns the path to the referenced *.node file.
// return the path to the reference node
Log::message("The referenced node is: %s\n",nodeRef->getNodePath());
Return value
Path to the referenced *.node file.
Ptr<Node> getReference ( ) #
Returns the node stored by the reference. The method should be used when you need to change the referenced node. If getReference() has returned a NodeDummy instance, it means that several nodes of the same hierarchy level has been converted into the NodeReference.
// create a NodeReference instance
NodeReferencePtr nodeRef = NodeReference::create("unigine_project/nodes/single_nref.node");
// get a node stored by the reference
NodePtr node = nodeRef->getReference();
// if the node is a NodeDummy
if (node->>getType() == Node::NODE_DUMMY){
	// print the type name of each child node of the root node stored by the reference
	for(int i = 0; i & node->getNumChildren(); i++) {
		Log::message("%d: %s\n",i,node->getChild(i)->getTypeName());
Return value
Node instance.
static bool canBeReference ( const char * name, const Ptr<Node> & node ) #
Returns a value indicating if the hierarchy of the given node does not contain a node reference with the given name.
Arguments
  • const char * name - Node reference name.
  • const Ptr<Node> & node - Node to check.
Return value
true if the hierarchy of the given node does not contain a node reference with the given name; otherwise, false.
Ptr<Node> detachReference ( ) #
Returns the node stored by the reference and releases this node of ownership so it is no longer owned and referred to by the NodeReference. The node is managed by the World.
To remove the node do the following:
// create a new NodeReference instance
NodeReferencePtr nodeRef = NodeReference::create("unigine_project/nodes/node_reference_0.node");
// perform something
// get the node stored by the reference and release NodeReference ownership of the node
NodePtr node = nodeRef->detachReference();
// destroy the NodeReference pointer as the NodeReference doesn't refer to a node any more
nodeRef.deleteForce();
Return value
Root node of the internal hierarchy.
static int type ( ) #
Returns the type of the node.
Return value
NodeReference type identifier.
Last update: 2021-12-13
