Unigine Basics
1. Introduction
2. Managing Virtual Worlds
3. Preparing 3D Models
4. Materials
5. Cameras and Lighting
9. Physics
10. Optimization Basics
GUI for Crosshair and Current Game Stats
In games and simulators, the HUD (Heads-Up Display) is used to showcase important information or graphical elements. Our project also requires a HUD, where we will display current game statistics and provide a crosshair to aid the player in shooting. To achieve this, we can obtain the current GUI (Graphical User Interface) and add the required widgets as children. For the crosshair in the center of the screen, we will use WidgetSprite, which enables us to display any image in the UI.
  1. Create a HUD component and copy the following code into it:
    HUD.h
    HUD.h
    #pragma once
    #include <UnigineGui.h>
    class HUD :
    	public Unigine::ComponentBase
    	COMPONENT_DEFINE(HUD, Unigine::ComponentBase);
    	// crosshair parameters
    	PROP_PARAM(File, crosshairImage, "");
    	PROP_PARAM(Int, crosshairSize, 16);
    	COMPONENT_INIT(init);
    	COMPONENT_UPDATE(update);
    	// link to the screen GUI
    	Unigine::GuiPtr screenGui = nullptr;
    protected:
    	Unigine::WidgetSpritePtr sprite = nullptr;
    	Unigine::Math::ivec2 prev_size;
    	// world main loop overrides
    	void init();
    	void update();
    HUD.cpp
    HUD.cpp
    #include "HUD.h"
    #include <UnigineGame.h>
    REGISTER_COMPONENT(HUD);
    void HUD::init()
    	// get the current screen GUI
    	screenGui = Gui::getCurrent();
    	// add WidgetSprite for crosshair
    	if (crosshairImage != "")
    		sprite = WidgetSprite::create(screenGui, Unigine::FileSystem::guidToPath(FileSystem::getGUID(crosshairImage.getRaw())));
    	// set the sprite size
    	sprite->setWidth(crosshairSize);
    	sprite->setHeight(crosshairSize);
    	// add the sprite to GUI so that it would always be in the center of the screen and overlap other widgets
    	screenGui->addChild(sprite, Gui::ALIGN_CENTER | Gui::ALIGN_OVERLAP);
    	// bind the widget lifetime to the world
    	sprite->setLifetime(Widget::LIFETIME_WORLD);
    void HUD::update()
    	ivec2 new_size = screenGui->getSize();
    	if (prev_size != new_size)
    		screenGui->removeChild(sprite);
    	prev_size = new_size;
    Save all the files that we modified and then build and run the application by hitting Ctrl + F5 to make the Component System update properties used to assign the components to nodes. Close the application after running it and switch to UnigineEditor.
  2. Create a NodeDummy, place it somewhere in the scene, name it HUD and add the HUD property to it.
  3. Add the data/fps/hud/crosshair.png file to the Crosshair Image field.
After compiling and running the application, you should get the following result:
