Using C++ Component System
The C++ Component System enables you to implement your application's logic via a set of building blocks — components, and assign these blocks to nodes. A logic component integrates a node, a property, and a C++ class containing logic implementation.
  • Decompose application logic into building blocks.
  • Create your own logic components.
  • Implement interaction between your components.
Let's make a simple game to demonstrate how the whole system works.
This case is also provided as an SDK sample.
Game Description#
In the center of the play area, we are going to have an object (Pawn) controlled by the player via the keyboard. It has certain amount of HP and movement parameters (movement and rotation speed).
Four corners of the play area are occupied by rotating objects (Spinner) that throw other small objects (Projectile) in all directions while rotating.
Each Projectile moves along a straight line in the directon it has been initially thrown by the Spinner. If a Projectile hits a Pawn, the Pawn takes damage according to the value set for the hitting Projectile (each of them has a random speed and damage value). The pawn is destroyed if the amount of HP drops below zero.
We use boxes for simplicity, but you can easily replace them with any other objects.
The basic workflow for implementing application logic using the C++ Component System is given below.
1. Prepare a Project#
Before we can start creating components and implementing our game logic, we should create a new C++ project.
2. Decompose Application Logic into Building Blocks#
First of all, we should decompose our application logic in terms of building blocks — components. So, we should define parameters for each component (all these parameters will be stored in a corresponding .prop file) and decide in which functions of the execution sequence the component's logic will be implemented.
For our small game, we are going to use one component for each type of object. Thus, we need 3 components:
  • Pawn with the following parameters:
    • name — name of the Pawn
    • moving speed — how fast the Pawn moves
    • rotation speed — how fast the Pawn rotates
    • health — HP count for the Pawn
    We are going to initialize a Pawn, do something with it each frame, and report a message, when the Pawn dies. Therefore, this logic will be implemented inside the init(), update(), and shutdown() methods.
  • Spinner with the following parameters:
    • rotation speed — how fast the Spinner rotates
    • acceleration — how fast Spinner's rotation rate increases
    • node to be used as a projectile
    • minimum spawn delay
    • maximum spawn delay
    We are going to initialize a Spinner and do something with it each frame. Therefore, this logic will go to the init() and update().
  • Projectile with the following parameters:
    • speed — how fast the Projectile moves
    • lifetime — how long the Projectile lives
    • damage — how much damage the Projectile causes to the Pawn it hits
    As for the projectile, it will be spawned and initialized by the Spinner. The only thing we are going to do with it, is checking for a hit and controlling the life time left every frame. All of this goes to update().
3. Create a C++ Class for Each Component#
For each of our components, we should derive a new C++ class from the ComponentBase class. Therefore, we should do the following in the header file:
  • Declare a component class. The name of the class is used as the name of the property (the corresponding .prop file is automatically saved in your project's data folder).
    To declare a class, use the following:
    COMPONENT_DEFINE(my_property_name, Unigine::ComponentBase);
  • Declare all parameters defined above with their default values (if any).
    To declare a parameter we can use the following macros (optional parameters are enclosed in square brackets []):
    PROP_PARAM(type, name[, default_value, title, tooltip, group]);
    PROP_STRUCT(type, name);
    PROP_ARRAY(type, name);
    PROP_ARRAY_STRUCT(type, name);
  • Declare which methods we are going to use to implement our logic, and during which stages of the execution sequence to call them:
    	COMPONENT_INIT(my_init);
    	COMPONENT_UPDATE(my_update);
    	COMPONENT_SHUTDOWN(my_shutdown);
    protected:
    	void my_init();
    	void my_update();
    	void my_shutdown();
  • Declare all necessary auxiliary parameters and functions.
Thus, for our Pawn, Spinner, and Projectile classes, we will have the following declarations:
Pawn.h
Pawn.h
#pragma once
#include <UnigineGame.h>
#include <UnigineControls.h>
// include the header file of the Component System
// derive our class from the ComponentBase
class Pawn : public ComponentBase
	// declare constructor and destructor for our class and define a property name. The Pawn.prop file containing all parameters listed below will be saved in your project's data folder
	COMPONENT_DEFINE(Pawn, ComponentBase)
		COMPONENT_INIT(init);
	COMPONENT_UPDATE(update);
	COMPONENT_SHUTDOWN(shutdown);
	// parameters
	PROP_PARAM(String, name, "Pawn1");		// Pawn's name
	PROP_PARAM(Int, health, 200);			// health points
	PROP_PARAM(Float, move_speed, 4.0f);	// move speed (meters/s)
	PROP_PARAM(Float, turn_speed, 90.0f);	// turn speed (deg/s)
	// methods
	void hit(int damage);	// decrease Pawn's HP
protected:
	// world main loop overrides
	void init();
	void update();
	void shutdown();
	// auxiliary parameters and functions
	ControlsPtr controls;
	PlayerPtr player;
	float damage_effect_timer = 0;
	Mat4 default_model_view;
	void show_damage_effect();
Spinner.h
Spinner.h
#pragma once
#include <UnigineMaterial.h>
class Spinner : public ComponentBase
	// declare constructor and destructor for the Spinner class
	COMPONENT_DEFINE(Spinner, ComponentBase);
	// parameters
	PROP_PARAM(Float, turn_speed, 30.0f);
	PROP_PARAM(Float, acceleration, 5.0f);
	PROP_PARAM(Node, spawn_node);
	PROP_PARAM(Float, min_spawn_delay, 1.0f);
	PROP_PARAM(Float, max_spawn_delay, 4.0f);
protected:
	// world main loop
	void init();
	void update();
	float start_turn_speed = 0;
	float color_offset = 0;
	float time_to_spawn = 0;
	MaterialPtr material;
	// converter from HSV to RGB color model
	vec3 hsv2rgb(float h, float s, float v);
Projectile.h
Projectile.h
#pragma once
class Projectile : public ComponentBase
	// declare constructor and destructor for the Projectile class
	COMPONENT(Projectile, ComponentBase);
	PROP_NAME("Projectile");
	// parameters
	PROP_PARAM(Float, speed, 5.0f);
	PROP_PARAM(Float, lifetime, 5.0f);	// life time of the projectile (declaration with a default value)
	PROP_PARAM(Int, damage);			// damage caused by the projectile (declaration with no default value)
	// methods
	void setMaterial(const MaterialPtr &mat);
protected:
	// world main loop
	void update();
4. Implement Each Component's Logic#
After making necessary declarations, we should implement logic for all our components. Let's do it in the corresponding .cpp files.
In each of these files, we should add the following macro to ensure automatic registration of the corresponding component by the Component System:
REGISTER_COMPONENT ( your_component_name );
Do not put this macro to header (*.h) files, otherwise your project won't be built!
Pawn's Logic#
The Pawn's logic is divided into the following elements:
  • Initialization — here we set necessary parameters, and the Pawn reports its name:
    Log::message("PAWN: INIT \"%s\"\n", name.get());
    You can access parameters of your component via: <parameter_name>.get()
  • Main loop — here we implement the player's keyboard control.
    To access the node from the component, we can simply use node, e.g. to get the current node's direction we can write:
    Vec3 direction = node->getWorldTransform().getColumn3(1);
  • Shutdown — here we implement actions to be performed when a Pawn dies. We'll just print a message to the console.
  • Auxiliary — a method to be called when the pawn is hit, and some visual effects.
Implementation of the Pawn's logic is given below:
Pawn.cpp
Pawn.cpp
#include "Pawn.h"
#include <UnigineConsole.h>
#include <UnigineRender.h>
REGISTER_COMPONENT(Pawn);		// macro for component registration by the Component System
#define DAMAGE_EFFECT_TIME 0.5f
void Pawn::init()
	player = Game::getPlayer();
	default_model_view = player->getCamera()->getModelview();
void Pawn::update()
	// get delta time between frames
	float ifps = Game::getIFps();
	// show damage effect
	if (damage_effect_timer > 0)
		damage_effect_timer = Math::clamp(damage_effect_timer - ifps, 0.0f, DAMAGE_EFFECT_TIME);
	// if console is opened we disable any controls
	if (Console::isActive())
		return;
	// get the direction vector of the mesh from the second column (y axis) of the transformation matrix
	// checking controls states and changing pawn position and rotation
		node->setWorldPosition(node->getWorldPosition() + direction * move_speed * ifps);
	if (controls->getState(Controls::STATE_BACKWARD) || controls->getState(Controls::STATE_TURN_DOWN))
		node->setWorldPosition(node->getWorldPosition() - direction * move_speed * ifps);
		node->setWorldRotation(node->getWorldRotation() * quat(0.0f, 0.0f, turn_speed * ifps));
	if (controls->getState(Controls::STATE_MOVE_RIGHT) || controls->getState(Controls::STATE_TURN_RIGHT))
		node->setWorldRotation(node->getWorldRotation() * quat(0.0f, 0.0f, -turn_speed * ifps));
void Pawn::shutdown()
	Log::message("PAWN: DEAD!\n");
// method to be called when the Pawn is hit by a Projectile
void Pawn::hit(int damage)
	// take damage
	health = health - damage;
	// show effect
	damage_effect_timer = DAMAGE_EFFECT_TIME;
	// destroy
	if (health <= 0)
		node.deleteLater();
	Log::message("PAWN: damage taken (%d) - HP left (%d)\n", damage, health.get());
// auxiliary method implementing visual damage effect
void Pawn::show_damage_effect()
	float strength = damage_effect_timer / DAMAGE_EFFECT_TIME;
	Render::setFadeColor(vec4(0.5f, 0, 0, saturate(strength - 0.5f)));
	player->getCamera()->setModelview(default_model_view * Mat4(
		rotateX(Game::getRandomFloat(-5, 5) * strength) *
		rotateY(Game::getRandomFloat(-5, 5) * strength)));
Projectile's Logic#
The Projectile's logic is simpler — we just have to perform a check each frame whether we hit the Pawn or not. This means that we have to access the Pawn component from the Projectile component.
To access certain component on a certain node (e.g. the one that was intersected in our case) we can write the following:
MyComponent *my_component = getComponent<MyComponent>(some_node);
// access some method of MyComponent
my_component->someMyComponentMethod();
The Projectile has a limited life time, so we should destroy the node when its life time is expired.
To destroy a node, to which a component is added, simply call: node.deleteLater(). The node will be destroyed with all its properties and components.
Implementation of the Projectile's logic is given below:
Projectile.cpp
Projectile.cpp
#include "Projectile.h"
#include "Pawn.h"
#include "Spinner.h"
#include <UnigineWorld.h>
REGISTER_COMPONENT(Projectile);		// macro for component registration by the Component System
void Projectile::update()
	// move forward
	node->setWorldPosition(node->getWorldPosition() + direction * speed * ifps);
	// lifetime
	lifetime = lifetime - ifps;
	if (lifetime < 0)
		// destroy current node with its properties and components
		node.deleteLater();
		return;
	// check the intersection with nodes
	VectorStack<NodePtr> nodes; // VectorStack is much faster than Vector, but has some limits
	World::getIntersection(node->getWorldBoundBox(), nodes);
	if (nodes.size() > 1) // (because the current node is also in this list)
		for (int i = 0; i < nodes.size(); i++)
			Pawn *pawn = getComponent<Pawn>(nodes[i]);
			if (pawn)
				// hit the player!
				pawn->hit(damage);
				// ...and destroy current node
				node.deleteLater();
				return;
void Projectile::setMaterial(const MaterialPtr &mat)
	checked_ptr_cast<Object>(node)->setMaterial(mat, "*");
Spinner's Logic#
The Spinner's logic is divided into the following elements:
  • Initialization — here we set necessary parameters to be used in the main loop.
  • Main loop — here we rotate our Spinner and spawn nodes with Projectile components. We also set some parameters of the Projectile.
    There are 3 ways to change variables of another component:
    1. Directly via component (fast, easy)
      component->int_parameter = component->int_parameter + 1;
    2. Via node's property (slower, more awkward)
      for (int i = 0; i < node->getNumProperties(); i++)
      	PropertyPtr prop = node->getProperty(i);
      	if (prop && (!strcmp(prop->getName(), "my_prop_name") || prop->isParent("my_prop_name")))
      		prop->setParameterInt(prop->findParameter("int_parameter"), 5);
    3. Via component's property
      PropertyPtr prop = component->getProperty();
      prop->setParameterInt(prop->findParameter("int_parameter"), 5));
  • Auxiliary — color conversion function.
Implementation of the Spinner's logic is given below:
Spinner.cpp
Spinner.cpp
#include <UnigineEditor.h>
REGISTER_COMPONENT(Spinner);		// macro for component registration by the Component System
void Spinner::init()
	// get current material (from the first surface)
	ObjectPtr obj = checked_ptr_cast<Object>(node);
	if (obj && obj->getNumSurfaces())
		material = obj->getMaterialInherit(0);
	// init randoms
	time_to_spawn = Game::getRandomFloat(min_spawn_delay, max_spawn_delay);
	color_offset = Game::getRandomFloat(0, 360.0f);
	start_turn_speed = turn_speed;
void Spinner::update()
	// rotate spinner
	turn_speed = turn_speed + acceleration * ifps;
	node->setRotation(node->getRotation() * quat(0, 0, turn_speed * ifps));
	// change color
	int id = material->findParameter("albedo_color");
	if (id != -1)
		float hue = Math::mod(Game::getTime() * 60.0f + color_offset, 360.0f);
		material->setParameterFloat4(id, vec4(hsv2rgb(hue, 1, 1), 1.0f));
	// spawn projectiles
	time_to_spawn -= ifps;
	if (time_to_spawn < 0 && spawn_node)
		// reset timer and increase difficulty
		time_to_spawn = Game::getRandomFloat(min_spawn_delay, max_spawn_delay) / (turn_speed / start_turn_speed);
		// create node
		NodePtr spawned = spawn_node->clone();
		spawned->setEnabled(1);
		spawned->setWorldTransform(node->getWorldTransform());
		// don't destroy it on quitting the current scope
		// note: if you plan to add some components to this object
		// you have to use release() method and transfer ownership of this
		// object to the Editor
		// create component
		Projectile *proj_component = addComponent<Projectile>(spawned);
		// there are three ways to change variables inside another component:
		// 1) direct change via component (fast, easy)
		proj_component->speed = Game::getRandomFloat(proj_component->speed * 0.5f, proj_component->speed * 1.5f);
		// 2) change via property of the node (more slow, more awkward)
		for (int i = 0; i < spawned->getNumProperties(); i++)
			PropertyPtr prop = spawned->getProperty(i);
			if (prop && (!strcmp(prop->getName(), "Projectile") || prop->isParent("Projectile")))
				prop->getParameterPtr("damage")->setValueInt(Game::getRandomInt(75, 100));
		// 3) change via property of the component
		PropertyPtr proj_property = proj_component->getProperty();
		proj_property->getParameterPtr("lifetime")->setValueFloat(Game::getRandomFloat(5.0f, 10.0f));
		// call public method of another component
		proj_component->setMaterial(material);
// color conversion H - [0, 360), S,V - [0, 1]
vec3 Spinner::hsv2rgb(float h, float s, float v)
	float p, q, t, fract;
	h /= 60.0f;
	fract = h - Math::floor(h);
	p = v * (1.0f - s);
	q = v * (1.0f - s * fract);
	t = v * (1.0f - s * (1.0f - fract));
	if (0.0f <= h && h < 1.0f) return vec3(v, t, p);
	else if (1.0f <= h && h < 2.0f) return vec3(q, v, p);
	else if (2.0f <= h && h < 3.0f) return vec3(p, v, t);
	else if (3.0f <= h && h < 4.0f) return vec3(p, q, v);
	else if (4.0f <= h && h < 5.0f) return vec3(t, p, v);
	else if (5.0f <= h && h < 6.0f) return vec3(v, p, q);
	else return vec3(0, 0, 0);
5. Register Components in the Component System#
Now we have all our game logic implemented in the corresponding components: Pawn, Spinner, and Projectile. There is one more thing to be done before we can start using them. We should register our components in the Component System.
All components having the REGISTER_COMPONENT macro declared in their implementation files (*.cpp), are registered automatically by the Component System upon its initialization, just add a single line to the AppSystemLogic::init() method:
int AppSystemLogic::init()
Voila! All our components are registered at once!
6. Add Components to Nodes#
As we implemented our game logic in the components and registered them in the System, we can actually start using them. There are two ways to add a logic component to a node:
  • By simply assigning the corresponding property to it via UnigineEditor or code:
    object1->addProperty("MyComponentProperty");
    object2->setProperty(0, "MyComponentProperty");
  • By calling the corresponding method of the Component System:
    ComponentSystem::get()->addComponent<MyComponent>(object);
Here is the resulting code for our game including registration of components as well as adding them to nodes:
game.cpp
game.cpp
#include <UnigineEngine.h>
#include <UnigineLights.h>
#include <UnigineWidgets.h>
#include "Pawn.h"
// System logic class
class AppSystemLogic : public SystemLogic
	AppSystemLogic() {}
	virtual ~AppSystemLogic() {}
	virtual int init()
		// run in background
		Engine::get()->setBackgroundUpdate(Engine::BACKGROUND_UPDATE_RENDER_NON_MINIMIZED);
		// load world
		World::loadWorld("cs");
// World logic class
class AppWorldLogic : public WorldLogic
	AppWorldLogic() {}
	virtual ~AppWorldLogic() {}
	virtual int init()
		// create static camera
		player = PlayerDummy::create();
		player->setPosition(Vec3(17.0f));
		player->setDirection(vec3(-1.0f), vec3(0.0f, 0.0f, 1.0f));
		Game::setPlayer(player);
		// create light
		sun = LightWorld::create(vec4_one);
		sun->setName("Sun");
		sun->setWorldRotation(Math::quat(45.0f, 30.0f, 300.0f));
		// Note: objects are added to the world when created
		// create objects
		ObjectMeshDynamicPtr obj[4];
		obj[0] = create_box(translate(Vec3(-16.0f, 0.0f, 0.0f)), vec3(1.0f));
		obj[1] = create_box(translate(Vec3(16.0f, 0.0f, 0.0f)), vec3(1.0f));
		obj[2] = create_box(translate(Vec3(0.0f, -16.0f, 0.0f)), vec3(1.0f));
		obj[3] = create_box(translate(Vec3(0.0f, 16.0f, 0.0f)), vec3(1.0f));
		// there are two ways to create components on nodes:
		// 1) via component system
		ComponentSystem::get()->addComponent<Spinner>(obj[0]);
		ComponentSystem::get()->addComponent<Spinner>(obj[1]);
		// 2) via property
		obj[2]->addProperty("Spinner");
		obj[3]->setProperty(0, "Spinner");
		// set up spinners (set "spawn_node" variable)
		ObjectMeshDynamicPtr projectile_obj = create_box(Mat4_identity, vec3(0.15f));
		projectile_obj->setEnabled(0);
		for (int i = 0; i < 4; i++)
			ComponentSystem::get()->getComponent<Spinner>(obj[i])->spawn_node = projectile_obj;
		// create player
		ObjectMeshDynamicPtr my_pawn_object = create_box(translate(Vec3(1.0f, 1.0f, 0.0f)), vec3(1.3f, 1.3f, 0.3f));
		my_pawn = ComponentSystem::get()->addComponent<Pawn>(my_pawn_object);
		my_pawn->setDestroyCallback(MakeCallback(this, &AppWorldLogic::my_pawn_destroyed));
		time = 0;
		// create info label
		label = WidgetLabel::create(Gui::getCurrent());
		label->setPosition(10, 10);
		label->setFontSize(24);
		label->setFontOutline(1);
		Gui::getCurrent()->addChild(label, Gui::ALIGN_OVERLAP);
	virtual int update()
		// increase time while player is alive
		if (my_pawn)
			time += Game::getIFps();
		// show game info
		label->setText(String::format(
			"Player:\n"
			"Health Points: %d\n"
			"Time: %.1f sec\n"
			"\n"
			"Statisics:\n"
			"Components: %d",
			(my_pawn ? my_pawn->health.get() : 0),
			time,
			ComponentSystem::get()->getNumComponents()).get());
	Pawn* my_pawn{ nullptr };	// Pawn player
	float time = 0;
	WidgetLabelPtr label;
	PlayerDummyPtr player;
	LightWorldPtr sun;
	void my_pawn_destroyed()
		my_pawn = nullptr;
	// method creating a box
	ObjectMeshDynamicPtr create_box(const Mat4 &transform, const vec3 &size)
		mesh->addBoxSurface("box", size);
		ObjectMeshDynamicPtr object = ObjectMeshDynamic::create(1);
		object->setMesh(mesh);
		object->setWorldTransform(transform);
		return object;
// Main
int main(int argc, char **argv)
	// init engine
	Unigine::Engine::InitParameters init_params;
	init_params.window_title = "UNIGINE Engine: Component System Usage Example (C++)";
	Unigine::EnginePtr engine(init_params, argc, argv);
	// enter main loop
	AppWorldLogic world_logic;
	AppSystemLogic system_logic;
	engine->main(&system_logic, &world_logic, NULL);
	return 0;
Last update: 2024-04-01
