复制用户文件
Sometimes you may want to add some files stored outside your project to the build (e.g. end-user agreement, etc.). User files are added to the build folder by filling in the following table:有时你可能需要将项目外部存储的某些文件(如最终用户协议等)添加到构建中。通过填写以下表格可将用户文件添加至构建文件夹:
- From (Absolute Path) — an absolute path to a source file or folder. Folders can be specified using wildcards.From (Absolute Path):源文件或文件夹的绝对路径。可使用通配符指定文件夹。
- To (Relative Path) — path to the destination folder that is relative of the Build Folder. It can be a name of the folder into which the file or files are copied, or folder name + file name (if you need to rename the copied file).To (Relative Path):相对于Build Folder(构建文件夹)的目标文件夹路径。可以是文件或文件夹将被复制到的目标文件夹名称,也可以是文件夹名称+文件名(如需重命名复制的文件)。
最新更新:
2025-06-09
