Bent Normal
This section contains settings related to bent normals.
Customizable Settings#
Bent Normal Settings
Enabled | The value indicating if ray-traced bent normals calculation is enabled. The use of SSRTGI for bent normals allows for smooth ambient lighting.
disabled by default.
Ray-traced bent normals calculation available only when the SSRTGI technique (see the SSRTGIPreset) is enabled. Console access: render_bent_normal (API control) |
Threshold | The threshold value for the ray-traced bent normals calculation. Notice Ray-traced bent normals calculation is available only when the SSRTGI technique (see the SSRTGIPreset) is enabled. Range of values: [0.0f, inf]. The default value is : 1.0f. Console access: render_bent_normal_threshold (API control) |
Fix Overlit Areas | The value indicating if correction of overlit areas for bent normals calculation is enabled.
Console access: render_bent_normal_fix_overlit_areas (API control) |
