Unigine::WindowManager Class
Header: #include <UnigineWindowManager.h>
The class to manage windows enabling you to access any window of the appllication, group or stack windows, create various dialogs and so on.
Accessing Windows#
An application window can be accessed via the getWindow() function. There are also some functions (like getMainWindow()) that allow accessing the specific windows (a focused window, a fullscreen window, the main application window, and so on). That's how you get an EngineWindow class instance (or its child) that you can use to set screen size/resolution, position on the screen, decoration etc.
// get the main window
EngineWindowPtr main_window = WindowManager::getMainWindow();
// change position and size(resolution) of the main window
if (main_window)
	main_window->setPosition(Math::ivec2(1020, 60));
	main_window->setSize(Math::ivec2(305, 670));
Grouping Windows#
The engine windows created via the EngineWindow class can be grouped. There are three types of the window groups:
  • Vertical
  • Horizontal
  • Group of tabs
The number of windows in the group is unlimited.
The WindowManager class provides two main functions for grouping windows:
// create separate windows
EngineWindowViewportPtr horizontal_1 = EngineWindowViewport::create("Horizontal 1", 512, 256);
EngineWindowViewportPtr horizontal_2 = EngineWindowViewport::create("Horizontal 2", 512, 256);
EngineWindowViewportPtr horizontal_3 = EngineWindowViewport::create("Horizontal 3", 512, 256);
EngineWindowViewportPtr horizontal_4 = EngineWindowViewport::create("Horizontal 4", 512, 256);
// create 2 horizontal window groups
EngineWindowGroupPtr horizontal_group_1 = WindowManager::stack(horizontal_1, horizontal_2, EngineWindowGroup::GROUP_TYPE_HORIZONTAL);
EngineWindowGroupPtr horizontal_group_2 = WindowManager::stack(horizontal_3, horizontal_4, EngineWindowGroup::GROUP_TYPE_HORIZONTAL);
// create a vertical group of 2 horizontal groups
EngineWindowGroupPtr vertical_group = WindowManager::stackGroups(horizontal_group_1, horizontal_group_2, EngineWindowGroup::GROUP_TYPE_VERTICAL);
// specify position, size, title of the verical window group
vertical_group->setPosition(Math::ivec2(50, 60));
vertical_group->setSize(Math::ivec2(565, 310));
vertical_group->setTitle("Vertical Group");
// render the window group
vertical_group->show();
Each window or window group has a state, so it changes after stacking.
There are also functions based on the stack() function that should be used in specific cases to avoid additional checking of arguments:
  • stackToParentGroup() stacks the second window to the parent group of the first window. In the result, both windows passed as arguments will be on the same level in the group hierarchy.
  • stackWindows() creates a group of the separate/nested windows. The windows are stacked in the default order.
  • stack() stacks the window to the other window. If the first argument is the separate window, a new window group is returned. If the first argument is the nested window, the window is added to its group.
  • stackToGroup() stacks the window or window group to another window group.
Follow the links to see the code examples.
For ungrouping, the unstack() function is used: it removes the window or the window group from the parent group.
Creating Dialog Windows#
To create a dialog window, use the corresponding functions of the class. For example:
// event handler function
int AppSystemLogic::onButtonClicked(const WidgetPtr &sender_widget, int buttons)
	// show the message dialog
	WindowManager::dialogMessage("Message", "The button has been pressed.");
int AppSystemLogic::init()
	// create a window with widgets in the client area
	auto create_window = [](const char *name)
		EngineWindowViewportPtr window = EngineWindowViewport::create(name, 512, 256);
		window->addChild(WidgetLabel::create(window->getSelfGui(), String::format("This is a %s.", name)), Gui::ALIGN_TOP);
		window->addChild(WidgetButton::create(window->getSelfGui(), name), Gui::ALIGN_CENTER);
		return window;
		// create a window
		EngineWindowViewportPtr window = create_window("Window");
		// get the child widget of the window
		WidgetPtr button = window->getChild(1);
		// subscribe to the Clicked event
		button->getEventClicked().connect(this, &AppSystemLogic::onButtonClicked);
		// show the window
		window->setPosition(Math::ivec2(50, 60));
		window->show();
WindowManager Class
枚举
DPI_AWARENESS#
Name描述
DPI_AWARENESS_CUSTOM = -1The DPI awareness is set not on the engine side. For example, when the application is integrated via CustomSystemProxy, the user sets the required mode.
DPI_AWARENESS_UNAWARE = CUSTOM + 1Scaling is not taken into account. Windows are displayed with the default DPI level of 96 (100%). The operating system will stretch the raster part of the window and it will look blurry.
DPI_AWARENESS_SYSTEM_AWARE = UNAWARE + 1The DPI level of the main system display is obtained. Only with this DPI level the image is displayed clearly. Displays with another DPI level of changing of the DPI value on the main system display while running the application will cause the image blurring.
DPI_AWARENESS_PER_MONITOR_AWARE = SYSTEM_AWARE + 1Windows get the DPI level from each display individually.
Not available on Linux.
Members
Ptr<EngineWindowViewport> getMainWindow() const#
Returns the current window viewport that is set as the main window by default.
There may be several windows that are set as main, or no main windows at all.
Return value
Current engine window viewport.
int getNumWindows() const#
Returns the current number of windows.
Return value
Current number of windows.
bool isFullscreenMode() const#
Returns the current value indicating if the window is the fullscreen state, or in the window mode.
Return value
true if the window is the fullscreen state; otherwise false.
bool isMultipleWindowsSupported() const#
Returns the current value indicating if the engine can create more than one window. In addition to the settings defined by the user, it is currently impossible to create more than one window using Vulkan and DirectX 12. GL and DirectX 11, however, allow creating multiple windows.
Return value
true if multiple windows are supported; otherwise false.
Ptr<EngineWindow> getFocusedWindow() const#
Returns the current window viewport which is currently in focus.
Return value
Current window viewport which is currently in focus.
Ptr<EngineWindow> getUnderCursorWindow() const#
Returns the current window viewport which is currently under cursor.
Return value
Current window viewport which is currently under cursor.
Ptr<EngineWindowViewport> getSystemFocusedWindow() const#
Returns the current engine window viewport that has the isSystemFocused() flag enabled, either a window itself or its parent group with the system focus is enabled. If there is no window with such a flag, nullptr is returned.
Return value
Current engine window viewport that has the isSystemFocused() flag enabled, or nullptr if there is no such window.
bool isAutoDpiScaling() const#
Returns the current value value specifying if automatic DPI scaling is applied to the window. If automatic DPI scaling is disabled, all GUI elements have the 100% size, only the system window size is scaled.
This value is stored in the boot config file and can be changed only at the application startup. It cannot be changed at runtime, thus at an attempt to change the value the console will show the corresponding warning.
Return value
true if all GUI elements of the window are scaled is enabled; otherwise false.
WindowManager::DPI_AWARENESS getDpiAwareness() const#
Returns the current DPI awareness mode, the value indicating how the application processes the DPI scaling. The value is set to PER_MONITOR_AWARE by default. On Windows, if a specified mode cannot be set, it will switch to a possible lower value with a corresponding warning. On Linux, PER_MONITOR_AWARE is currently not supported, setting this value will switch the mode to the SYSTEM_AWARE mode with the corresponding warning in the console.
Return value
Current DPI awareness mode, the value indicating how the application processes the DPI scaling.
WindowManager::DPI_AWARENESS getCurrentDpiAwareness() const#
Returns the current current actual DPI awareness mode, the value indicating how the application processes the DPI scaling. The value is set to PER_MONITOR_AWARE by default. On Windows, if a specified mode cannot be set, it will switch to a possible lower value with a corresponding warning. On Linux, PER_MONITOR_AWARE is currently not supported, setting this value will switch the mode to the SYSTEM_AWARE mode with the corresponding warning in the console.
This is an actual value, it may differ from the mode stored in the boot config file (in case the system cannot set the specified mode it will try to use the one that is suitable instead).
Return value
Current actual DPI awareness mode, the value indicating how the application processes the DPI scaling.
static Event<const Ptr<WindowEvent> &> getEventImmediateWindowEvent() const#
event triggered immediately as event from the window is received from proxy before being processed by the engine. This event can be triggered in different threads depending on the proxy implementation. You can subscribe to events via connect()  and unsubscribe via disconnect(). You can also use EventConnection  and EventConnections  classes for convenience (see examples below).
The event handler signature is as follows: myhandler(const Ptr<WindowEvent> & event)
Usage Example
// implement the ImmediateWindowEvent event handler
void immediatewindowevent_event_handler(const Ptr<WindowEvent> & event)
	Log::message("\Handling ImmediateWindowEvent event\n");
EventConnections immediatewindowevent_event_connections;
WindowManager::getEventImmediateWindowEvent().connect(immediatewindowevent_event_connections, immediatewindowevent_event_handler);
WindowManager::getEventImmediateWindowEvent().connect(immediatewindowevent_event_connections, [](const Ptr<WindowEvent> & event) {
		Log::message("\Handling ImmediateWindowEvent event (lambda).\n");
immediatewindowevent_event_connections.disconnectAll();
EventConnection immediatewindowevent_event_connection;
// subscribe to the ImmediateWindowEvent event with a handler function keeping the connection
WindowManager::getEventImmediateWindowEvent().connect(immediatewindowevent_event_connection, immediatewindowevent_event_handler);
immediatewindowevent_event_connection.setEnabled(false);
immediatewindowevent_event_connection.setEnabled(true);
// remove subscription to the ImmediateWindowEvent event via the connection
immediatewindowevent_event_connection.disconnect();
// Class handling the event
class SomeClass
	// A ImmediateWindowEvent event handler implemented as a class member
	void event_handler(const Ptr<WindowEvent> & event)
WindowManager::getEventImmediateWindowEvent().connect(sc->e_connections, sc, &SomeClass::event_handler);
delete sc;
EventConnectionId immediatewindowevent_handler_id;
// subscribe to the ImmediateWindowEvent event with a lambda handler function and keeping connection ID
immediatewindowevent_handler_id = WindowManager::getEventImmediateWindowEvent().connect(e_connections, [](const Ptr<WindowEvent> & event) {
WindowManager::getEventImmediateWindowEvent().disconnect(immediatewindowevent_handler_id);
//   5. Ignoring all ImmediateWindowEvent events when necessary
WindowManager::getEventImmediateWindowEvent().setEnabled(false);
WindowManager::getEventImmediateWindowEvent().setEnabled(true);
Return value
Event reference.
static Event<const Ptr<EngineWindow> &> getEventWindowUnstacked() const#
event triggered after the window has been unstacked. You can subscribe to events via connect()  and unsubscribe via disconnect(). You can also use EventConnection  and EventConnections  classes for convenience (see examples below).
The event handler signature is as follows: myhandler(const Ptr<EngineWindow> & window)
Usage Example
// implement the WindowUnstacked event handler
void windowunstacked_event_handler(const Ptr<EngineWindow> & window)
	Log::message("\Handling WindowUnstacked event\n");
EventConnections windowunstacked_event_connections;
WindowManager::getEventWindowUnstacked().connect(windowunstacked_event_connections, windowunstacked_event_handler);
WindowManager::getEventWindowUnstacked().connect(windowunstacked_event_connections, [](const Ptr<EngineWindow> & window) {
		Log::message("\Handling WindowUnstacked event (lambda).\n");
windowunstacked_event_connections.disconnectAll();
EventConnection windowunstacked_event_connection;
// subscribe to the WindowUnstacked event with a handler function keeping the connection
WindowManager::getEventWindowUnstacked().connect(windowunstacked_event_connection, windowunstacked_event_handler);
windowunstacked_event_connection.setEnabled(false);
windowunstacked_event_connection.setEnabled(true);
// remove subscription to the WindowUnstacked event via the connection
windowunstacked_event_connection.disconnect();
class SomeClass
	// A WindowUnstacked event handler implemented as a class member
	void event_handler(const Ptr<EngineWindow> & window)
WindowManager::getEventWindowUnstacked().connect(sc->e_connections, sc, &SomeClass::event_handler);
delete sc;
EventConnectionId windowunstacked_handler_id;
// subscribe to the WindowUnstacked event with a lambda handler function and keeping connection ID
windowunstacked_handler_id = WindowManager::getEventWindowUnstacked().connect(e_connections, [](const Ptr<EngineWindow> & window) {
WindowManager::getEventWindowUnstacked().disconnect(windowunstacked_handler_id);
//   5. Ignoring all WindowUnstacked events when necessary
WindowManager::getEventWindowUnstacked().setEnabled(false);
WindowManager::getEventWindowUnstacked().setEnabled(true);
Return value
Event reference.
static Event<const Ptr<EngineWindow> &> getEventWindowStacked() const#
event triggered after the window has been stacked. You can subscribe to events via connect()  and unsubscribe via disconnect(). You can also use EventConnection  and EventConnections  classes for convenience (see examples below).
Usage Example
// implement the WindowStacked event handler
void windowstacked_event_handler(const Ptr<EngineWindow> & window)
	Log::message("\Handling WindowStacked event\n");
EventConnections windowstacked_event_connections;
WindowManager::getEventWindowStacked().connect(windowstacked_event_connections, windowstacked_event_handler);
WindowManager::getEventWindowStacked().connect(windowstacked_event_connections, [](const Ptr<EngineWindow> & window) {
		Log::message("\Handling WindowStacked event (lambda).\n");
windowstacked_event_connections.disconnectAll();
EventConnection windowstacked_event_connection;
// subscribe to the WindowStacked event with a handler function keeping the connection
WindowManager::getEventWindowStacked().connect(windowstacked_event_connection, windowstacked_event_handler);
windowstacked_event_connection.setEnabled(false);
windowstacked_event_connection.setEnabled(true);
// remove subscription to the WindowStacked event via the connection
windowstacked_event_connection.disconnect();
class SomeClass
	// A WindowStacked event handler implemented as a class member
WindowManager::getEventWindowStacked().connect(sc->e_connections, sc, &SomeClass::event_handler);
delete sc;
EventConnectionId windowstacked_handler_id;
// subscribe to the WindowStacked event with a lambda handler function and keeping connection ID
windowstacked_handler_id = WindowManager::getEventWindowStacked().connect(e_connections, [](const Ptr<EngineWindow> & window) {
WindowManager::getEventWindowStacked().disconnect(windowstacked_handler_id);
//   5. Ignoring all WindowStacked events when necessary
WindowManager::getEventWindowStacked().setEnabled(false);
WindowManager::getEventWindowStacked().setEnabled(true);
Return value
Event reference.
static Event<const Ptr<EngineWindow> &> getEventWindowRemoved() const#
event triggered after the window has been removed. You can subscribe to events via connect()  and unsubscribe via disconnect(). You can also use EventConnection  and EventConnections  classes for convenience (see examples below).
Usage Example
// implement the WindowRemoved event handler
void windowremoved_event_handler(const Ptr<EngineWindow> & window)
	Log::message("\Handling WindowRemoved event\n");
EventConnections windowremoved_event_connections;
WindowManager::getEventWindowRemoved().connect(windowremoved_event_connections, windowremoved_event_handler);
WindowManager::getEventWindowRemoved().connect(windowremoved_event_connections, [](const Ptr<EngineWindow> & window) {
		Log::message("\Handling WindowRemoved event (lambda).\n");
windowremoved_event_connections.disconnectAll();
EventConnection windowremoved_event_connection;
// subscribe to the WindowRemoved event with a handler function keeping the connection
WindowManager::getEventWindowRemoved().connect(windowremoved_event_connection, windowremoved_event_handler);
windowremoved_event_connection.setEnabled(false);
windowremoved_event_connection.setEnabled(true);
// remove subscription to the WindowRemoved event via the connection
windowremoved_event_connection.disconnect();
class SomeClass
	// A WindowRemoved event handler implemented as a class member
WindowManager::getEventWindowRemoved().connect(sc->e_connections, sc, &SomeClass::event_handler);
delete sc;
EventConnectionId windowremoved_handler_id;
// subscribe to the WindowRemoved event with a lambda handler function and keeping connection ID
windowremoved_handler_id = WindowManager::getEventWindowRemoved().connect(e_connections, [](const Ptr<EngineWindow> & window) {
WindowManager::getEventWindowRemoved().disconnect(windowremoved_handler_id);
//   5. Ignoring all WindowRemoved events when necessary
WindowManager::getEventWindowRemoved().setEnabled(false);
WindowManager::getEventWindowRemoved().setEnabled(true);
Return value
Event reference.
static Event<const Ptr<EngineWindow> &> getEventWindowCreated() const#
event triggered after the window has been created. You can subscribe to events via connect()  and unsubscribe via disconnect(). You can also use EventConnection  and EventConnections  classes for convenience (see examples below).
Usage Example
// implement the WindowCreated event handler
void windowcreated_event_handler(const Ptr<EngineWindow> & window)
	Log::message("\Handling WindowCreated event\n");
EventConnections windowcreated_event_connections;
WindowManager::getEventWindowCreated().connect(windowcreated_event_connections, windowcreated_event_handler);
WindowManager::getEventWindowCreated().connect(windowcreated_event_connections, [](const Ptr<EngineWindow> & window) {
		Log::message("\Handling WindowCreated event (lambda).\n");
windowcreated_event_connections.disconnectAll();
EventConnection windowcreated_event_connection;
// subscribe to the WindowCreated event with a handler function keeping the connection
WindowManager::getEventWindowCreated().connect(windowcreated_event_connection, windowcreated_event_handler);
windowcreated_event_connection.setEnabled(false);
windowcreated_event_connection.setEnabled(true);
// remove subscription to the WindowCreated event via the connection
windowcreated_event_connection.disconnect();
class SomeClass
	// A WindowCreated event handler implemented as a class member
WindowManager::getEventWindowCreated().connect(sc->e_connections, sc, &SomeClass::event_handler);
delete sc;
EventConnectionId windowcreated_handler_id;
// subscribe to the WindowCreated event with a lambda handler function and keeping connection ID
windowcreated_handler_id = WindowManager::getEventWindowCreated().connect(e_connections, [](const Ptr<EngineWindow> & window) {
WindowManager::getEventWindowCreated().disconnect(windowcreated_handler_id);
//   5. Ignoring all WindowCreated events when necessary
WindowManager::getEventWindowCreated().setEnabled(false);
WindowManager::getEventWindowCreated().setEnabled(true);
Return value
Event reference.
Ptr<EngineWindowViewport> getFullscreenWindow() const#
Returns the current first engine window viewport that is in the fullscreen state.
Return value
Current The viewport in the fullscreen state, or nullptr if no window is found.
Ptr<EngineWindow> getWindow ( int index ) #
Returns the window by its index.
Arguments
  • int index - Index of the window.
Return value
Engine window.
int getWindowIndex ( const Ptr<EngineWindow> & window ) const#
Returns the index of the specified window.
Arguments
Return value
Ptr<EngineWindowGroup> stack ( const Ptr<EngineWindow> & first_window, const Ptr<EngineWindow> & second_window, EngineWindowGroup::GROUP_TYPE group_type, int index = -1, bool decompose_second = false ) #
Stacks the window to the other window. If the first argument is the separate window, a new window group is returned. If the first argument is the nested window, the window is added to its group.
EngineWindowPtr window_1 = EngineWindowViewport::create("Window 1", 512, 256);
EngineWindowPtr window_2 = EngineWindowViewport::create("Window 2", 512, 256);
EngineWindowPtr window_3 = EngineWindowViewport::create("Window 3", 512, 256);
// create a group of 2 windows
EngineWindowGroupPtr group_1 = WindowManager::stack(window_1, window_2, EngineWindowGroup::GROUP_TYPE_HORIZONTAL);
// stack a separate window to the window from the window group
WindowManager::stack(window_1, window_3, EngineWindowGroup::GROUP_TYPE_VERTICAL);
In the result, group_1 will consist of 3 windows: window_1 and window_3 stacked vertically and window_2 stacked horizontally.
Arguments
  • const Ptr<EngineWindow> & first_window - The parent window to which another window is stacked.
  • const Ptr<EngineWindow> & second_window - The window to be stacked.
  • EngineWindowGroup::GROUP_TYPE group_type - Type of a group to be created.
  • int index
  • bool decompose_second - Flag to decompose the second argument of the merge, if it is a group, and combine with the first group.
Return value
Group of stacked windows.
Ptr<EngineWindowGroup> stackToParentGroup ( const Ptr<EngineWindow> & window_in_group, const Ptr<EngineWindow> & window, int index = -1, bool decompose_second = false ) #
Stacks the second window to the parent window group of the first window. In the result, both windows passed as arguments will be on the same level in the group hierarchy. If the first window has no parent group, the function will return it as is.
// stack 2 separate windows
EngineWindowGroupPtr group_0 = WindowManager::stack(window_1, window_2, EngineWindowGroup::GROUP_TYPE_HORIZONTAL);
// stack a separate window to the parent group of "window_1"
WindowManager::stackToParentGroup(window_1, window_3);
Arguments
  • const Ptr<EngineWindow> & window_in_group - The window into the parent group of which the other window is stacked.
  • const Ptr<EngineWindow> & window - The window to be stacked.
  • int index - A place where a window or a group should be placed in a group.
  • bool decompose_second - Flag to decompose the second argument of the merge, if it is a group, and combine with the first window or a group.
Return value
Group of windows.
Ptr<EngineWindowGroup> stackWindows ( const Ptr<EngineWindowViewport> & first_viewport, const Ptr<EngineWindowViewport> & second_viewport, EngineWindowGroup::GROUP_TYPE group_type = Enum.EngineWindowGroup.GROUP_TYPE.TAB ) #
Returns a newly created group of the separate and/or nested windows. You cannot stack the window group to the separate window, however, you can stack a window nested in the window group: in this case, the window will be unstacked from its parent group and added to the new one. The windows are stacked in the default order. For example:
EngineWindowViewportPtr window_1 = EngineWindowViewport::create("Window 1", 512, 256);
EngineWindowViewportPtr window_2 = EngineWindowViewport::create("Window 2", 512, 256);
EngineWindowViewportPtr window_3 = EngineWindowViewport::create("Window 3", 512, 256);
// stack a window from the window group to a separate window
EngineWindowGroupPtr group_1 = WindowManager::stackWindows(window_3, window_1, EngineWindowGroup::GROUP_TYPE_VERTICAL);
In the result, group_1 will be a vertical group of window_3 and window_1.
Arguments
Return value
Group of windows.
Ptr<EngineWindowGroup> stackWithWindow ( const Ptr<EngineWindowViewport> & window_viewport, const Ptr<EngineWindow> & window, EngineWindowGroup::GROUP_TYPE group_type, bool decompose_second = false ) #
Returns a newly created group of the engine window viewport and any other engine window — another viewport or a window group.
Arguments
  • const Ptr<EngineWindowViewport> & window_viewport - The window viewport to be stacked.
  • EngineWindowGroup::GROUP_TYPE group_type - Type of a window group to be created.
Return value
Group of windows.
Ptr<EngineWindowGroup> stackGroups ( const Ptr<EngineWindowGroup> & first_group, const Ptr<EngineWindowGroup> & second_group, EngineWindowGroup::GROUP_TYPE group_type ) #
Returns the group of window groups. The second group is added to the first group. To combine two windows or a group and a window, use the stack() method.
EngineWindowPtr window_4 = EngineWindowViewport::create("Window 4", 512, 256);
// create 2 horizontal groups of windows
EngineWindowGroupPtr group_2 = WindowManager::stack(window_3, window_4, EngineWindowGroup::GROUP_TYPE_HORIZONTAL);
// stack one group to another to create a new vertical group
EngineWindowGroupPtr group_3 = WindowManager::stackGroups(group_1, group_2, EngineWindowGroup::GROUP_TYPE_VERTICAL);
Arguments
Return value
Group of windows.
Ptr<EngineWindowGroup> stackToGroup ( const Ptr<EngineWindowGroup> & destination_group, const Ptr<EngineWindow> & group, int index = -1, bool decompose_second = false ) #
Stacks the window or window group to another window group. The updated group of windows is returned.
WindowManager::stackToGroup(group_1, group_2);
Arguments
  • const Ptr<EngineWindowGroup> & destination_group - The parent group to which another group is stacked.
  • const Ptr<EngineWindow> & group - The window or window group to be stacked.
  • bool decompose_second - Flag to decompose the second argument of the merge and combine with the first group.
Return value
void unstack ( const Ptr<EngineWindow> & unstacked ) #
Removes a window or a group from a parent group. If there is only one window left, the group is automatically deleted after removing the window from it.
Arguments
  • const Ptr<EngineWindow> & unstacked - A window or a group to be removed from a parent group.
bool isFullscreenWindow ( const Ptr<EngineWindow> & window ) #
Returns the value indicating if the specified window is in a fullscreen state.
Arguments
Return value
true if the engine window is the fullscreen state, false if it is in the window mode.
Ptr<EngineWindowViewport> getFullscreenWindow ( ) const#
Returns the first engine window viewport that is in the fullscreen state.
Return value
Ptr<EngineWindow> getWindowByID ( unsigned long long win_id ) const#
Returns the window by its ID.
Arguments
  • unsigned long long win_id - Window ID.
Return value
Window with the specified ID, or nullptr if the window is not found.
bool dialogMessage ( const char * title, const char * message ) #
Displays a message dialog with the specified title and text.
Arguments
  • const char * title - Title of the message dialog to be displayed.
  • const char * message - Message text to be displayed.
Return value
true if the message is displayed successfully; otherwise, false.
bool dialogWarning ( const char * title, const char * warning ) #
Displays a warning dialog with the specified title and text.
Arguments
  • const char * title - Title of the warning dialog to be displayed.
  • const char * warning - Warning message text to be displayed.
Return value
bool dialogError ( const char * title, const char * error ) #
Displays an error dialog with the specified title and text.
Arguments
  • const char * title - Title of the error dialog to be displayed.
  • const char * error - Error message text to be displayed.
Return value
int showSystemDialog ( const Ptr<SystemDialog> & dialog ) #
Displays a custom system dialog with an arbitrary set of buttons.
Arguments
Return value
Number of the dialog button clicked by the user; or -1 if an error has occurred.
const char * dialogOpenFolder ( const char * path ) #
Opens a common dialog enabling the user to specify a folder to open. When the dialog opens the specified default path shall be set displaying the corresponding elements.
Arguments
  • const char * path - Path to be set by default when the dialog opens.
Return value
Resulting folder name specified by the user.
const char * dialogOpenFolder ( ) #
Return value
Vector<String> dialogOpenFiles ( const char * path, const char * filter ) #
Opens a common dialog enabling the user to specify a list of filenames to open multiple files. When the dialog opens the specified default path and file filter shall be set displaying the corresponding elements.
Arguments
  • const char * filter - File name filter string to be set by default when the dialog opens. This filter string determines file type choices to be displayed in the Files of type box.
Return value
Resulting list of filenames specified by the user.
Vector<String> dialogOpenFiles ( const char * path ) #
Opens a common dialog enabling the user to specify a list of filenames to open multiple files. When the dialog opens the specified default path shall be set displaying the corresponding elements.
Arguments
Return value
Vector<String> dialogOpenFiles ( ) #
Return value
const char * dialogOpenFile ( const char * path, const char * filter ) #
Opens a common dialog enabling the user to specify a filename to open a file. When the dialog opens the specified default path and file filter shall be set displaying the corresponding elements.
Arguments
Return value
Resulting filename specified by the user.
const char * dialogOpenFile ( const char * path ) #
Opens a common dialog enabling the user to specify a filename to open a file. When the dialog opens the specified default path shall be set displaying the corresponding elements.
Arguments
Return value
const char * dialogOpenFile ( ) #
Return value
const char * dialogSaveFile ( const char * path, const char * filter ) #
Opens a common dialog enabling the user to specify a filename to save a file as. When the dialog opens the specified default path and file filter shall be set displaying the corresponding elements.
Arguments
  • const char * filter - File name filter string to be set by default when the dialog opens. This filter string determines file type choices to be displayed in the Save as file type or Files of type box.
Return value
const char * dialogSaveFile ( const char * path ) #
Opens a common dialog enabling the user to specify a filename to save a file as. When the dialog opens the specified default path shall be set displaying the corresponding elements.
Arguments
Return value
const char * dialogSaveFile ( ) #
Return value
Ptr<EngineWindow> getIntersection ( const Math::ivec2 & global_pos, const Vector<Ptr<EngineWindow>> & excludes ) const#
Returns the window the intersection with which is detected.
Arguments
  • const Math::ivec2 & global_pos - The position of the intersection point in global coordinates.
  • const Vector<Ptr<EngineWindow>> & excludes - The windows to be excluded from the intersection detection.
Return value
The window the intersection with which is detected.
Ptr<EngineWindow> getIntersection ( const Math::ivec2 & global_pos ) const#
Arguments
Return value
void forceUpdateWindowOrders ( ) #
Updates the Z order of all windows.
It is recommended to use this method only when required, because it is very slow.
void setEventsFilter ( int (*)(const Ptr<InputEvent> &) func ) #
Sets a callback function to be executed on receiving input events. This input event filter enables you to reject certain input events for the Engine and get necessary information on all input events.
Arguments
