API Samples
Unigine::AsyncQueue Class
Header: #include <UnigineAsyncQueue.h>
Loading of files/meshes/images/nodes on demand is performed in a separate system thread, in addition to asynchronous content streaming. This class is used to control asynchronous data loading. It is possible to control loading queue by organizing files in groups and setting individual weights inside these groups.
To load files on demand, call the functions in the following order:
  1. First loadFile() function is called to place the file in the queue for loading and obtain an ID, that will be used to identify a resource in subsequent operations.
  2. After that, different operations can be performed:
    • forceFile() to load the file immediately.
    • removeFile() to remove the file from the queue in case there is no need to load it any more of to remove a file from the list of loaded files if it was loaded but no longer needed.
    • checkFile() to check if the given file was requested to be loaded via loadFile() or if it has already been loaded.
The same algorithm is true for:
To get a loaded resource (image, mesh, or node) the following 2 groups of methods can be used:
For example:
AsyncSample.cpp
// specify relative paths to resources to be loaded to a queue
static const char *meshes[] = {
	"meshes/box.mesh",
	"meshes/capsule.mesh",
	"meshes/cbox.mesh",
#define ARRAY_LENGTH(array) static_cast<int>(sizeof(array) / sizeof(array[0]))
struct AsyncLoadRequest
	String name;
	int id;
Vector<AsyncLoadRequest> mesh_load_requests;
void AsyncSample::init()
	// enqueue meshes to load
	for (int i = 0; i < ARRAY_LENGTH(meshes); ++i)
		const char *name = meshes[i];
		AsyncLoadRequest request;
		request.name = name;
		request.id = AsyncQueue::loadMesh(name);
		mesh_load_requests.append(request);
void AsyncSample::update()
	// check mesh load requests
	for (int i = 0; i < mesh_load_requests.size(); ++i)
		const auto &r = mesh_load_requests[i];
		if (!AsyncQueue::checkMesh(r.id))
			continue;
		// remove the mesh from the list of the loaded meshes and print a message
		AsyncQueue::removeMesh(r.id);
		Log::message("Loaded mesh \"%s\"\n", r.name.get());
		mesh_load_requests.remove(i--);
Handling Events#
You can add "resource loaded" event handlers for files, images, meshes or nodes and perform certain actions as a resource is loaded. The example below shows how to add a "loaded" event handler for image resource, that reports the name and id of the loaded image.
Do not call take-methods inside a handler function unless you are absolutely sure, that the resource is yours, otherwise internal engine managers will be forced to load it again and again every time. In such cases it is recommended to use get-methods.
AsyncSample.cpp
static const char *textures[] = {
	"textures/black_d.texture",
	"textures/blue_d.texture",
	"textures/green_d.texture",
	"textures/orange_d.texture",
	"textures/red_d.texture",
	"textures/white_d.texture",
	"textures/yellow_d.texture",
	// enqueue textures to load
	for (int i = 0; i < ARRAY_LENGTH(textures); ++i)
		AsyncQueue::loadImage(textures[i]);
	// subscribing for the ImageLoaded event
	AsyncQueue::getEventImageLoaded().connect(this, &AsyncSample::image_loaded);
// image loaded event handler function
void AsyncSample::image_loaded(const char *name, int id)
	AsyncQueue::removeImage(id);
	Log::message("Image \"%s\" loaded, ID: %d\n", name, id);
This class is a singleton.
A set of UnigineScript API samples located in the <UnigineSDK>/data/samples/systems/ folder:
  • async_02
  • stream_00
AsyncQueue Class
Members
int getNumLoadedResources() const#
Returns the current total number of currently loaded resources.
Return value
Current total number of currently loaded resources — the sum of currently loaded data, files, images and meshes.
int getNumLoadedNodes() const#
Returns the current total number of loaded nodes.
Return value
Current total number of loaded nodes including currently processed ones.
int getNumLoadedMeshes() const#
Returns the current total number of loaded meshes.
Return value
Current total number of loaded meshes.
int getNumLoadedImages() const#
Returns the current total number of loaded images.
Return value
Current total number of loaded images.
int getNumLoadedFiles() const#
Returns the current total number of loaded files.
Return value
Current total number of loaded files.
int getNumLoadedData() const#
Returns the current total number of loaded data segments.
Return value
Current total number of loaded data segments.
int getNumQueuedResources() const#
Returns the current total number of queued resources waiting for background loading.
Return value
Current total number of queued resources waiting for background loading — the sum of queued and currently processed data, files, images and meshes.
int getNumQueuedNodes() const#
Returns the current total number of queued nodes waiting for the background loading.
Return value
Current total number of queued nodes waiting for the background loading including currently processed ones.
int getNumQueuedMeshes() const#
Returns the current total number of queued meshes waiting for the background loading.
Return value
Current total number of queued meshes waiting for the background loading including currently processed ones.
int getNumQueuedImages() const#
Returns the current total number of queued images waiting for the background loading.
Return value
Current total number of queued images waiting for the background loading including currently processed ones.
int getNumQueuedFiles() const#
Returns the current total number of queued files waiting for the background loading.
Return value
Current total number of queued files waiting for the background loading including currently processed ones.
int getNumQueuedData() const#
Returns the current total number of queued data segments waiting for the background loading.
Return value
Current total number of queued data segments waiting for the background loading including currently processed ones.
float getTotalTime() const#
Returns the current total time it took to process the loading queue.
Return value
Current total time it took to process the loading queue.
static Event<const char *, int> getEventNodeLoaded() const#
event triggered when the node is loaded. You can subscribe to events via connect()  and unsubscribe via disconnect(). You can also use EventConnection  and EventConnections  classes for convenience (see examples below).
The event handler signature is as follows: myhandler(const char * name, int id)
See Example
Usage Example
// implement the NodeLoaded event handler
void nodeloaded_event_handler(const char * name,  int id)
	Log::message("\Handling NodeLoaded event\n");
EventConnections nodeloaded_event_connections;
AsyncQueue::getEventNodeLoaded().connect(nodeloaded_event_connections, nodeloaded_event_handler);
AsyncQueue::getEventNodeLoaded().connect(nodeloaded_event_connections, [](const char * name,  int id) {
		Log::message("\Handling NodeLoaded event (lambda).\n");
nodeloaded_event_connections.disconnectAll();
EventConnection nodeloaded_event_connection;
// subscribe to the NodeLoaded event with a handler function keeping the connection
AsyncQueue::getEventNodeLoaded().connect(nodeloaded_event_connection, nodeloaded_event_handler);
nodeloaded_event_connection.setEnabled(false);
nodeloaded_event_connection.setEnabled(true);
// remove subscription to the NodeLoaded event via the connection
nodeloaded_event_connection.disconnect();
// Class handling the event
class SomeClass
	// A NodeLoaded event handler implemented as a class member
	void event_handler(const char * name,  int id)
AsyncQueue::getEventNodeLoaded().connect(sc->e_connections, sc, &SomeClass::event_handler);
delete sc;
EventConnectionId nodeloaded_handler_id;
// subscribe to the NodeLoaded event with a lambda handler function and keeping connection ID
nodeloaded_handler_id = AsyncQueue::getEventNodeLoaded().connect(e_connections, [](const char * name,  int id) {
AsyncQueue::getEventNodeLoaded().disconnect(nodeloaded_handler_id);
//   5. Ignoring all NodeLoaded events when necessary
AsyncQueue::getEventNodeLoaded().setEnabled(false);
AsyncQueue::getEventNodeLoaded().setEnabled(true);
Return value
Event reference.
static Event<const char *, int> getEventMeshLoaded() const#
event triggered when the mesh is loaded. You can subscribe to events via connect()  and unsubscribe via disconnect(). You can also use EventConnection  and EventConnections  classes for convenience (see examples below).
See Example
Usage Example
// implement the MeshLoaded event handler
void meshloaded_event_handler(const char * name,  int id)
	Log::message("\Handling MeshLoaded event\n");
EventConnections meshloaded_event_connections;
AsyncQueue::getEventMeshLoaded().connect(meshloaded_event_connections, meshloaded_event_handler);
AsyncQueue::getEventMeshLoaded().connect(meshloaded_event_connections, [](const char * name,  int id) {
		Log::message("\Handling MeshLoaded event (lambda).\n");
meshloaded_event_connections.disconnectAll();
EventConnection meshloaded_event_connection;
// subscribe to the MeshLoaded event with a handler function keeping the connection
AsyncQueue::getEventMeshLoaded().connect(meshloaded_event_connection, meshloaded_event_handler);
meshloaded_event_connection.setEnabled(false);
meshloaded_event_connection.setEnabled(true);
// remove subscription to the MeshLoaded event via the connection
meshloaded_event_connection.disconnect();
class SomeClass
	// A MeshLoaded event handler implemented as a class member
AsyncQueue::getEventMeshLoaded().connect(sc->e_connections, sc, &SomeClass::event_handler);
delete sc;
EventConnectionId meshloaded_handler_id;
// subscribe to the MeshLoaded event with a lambda handler function and keeping connection ID
meshloaded_handler_id = AsyncQueue::getEventMeshLoaded().connect(e_connections, [](const char * name,  int id) {
AsyncQueue::getEventMeshLoaded().disconnect(meshloaded_handler_id);
//   5. Ignoring all MeshLoaded events when necessary
AsyncQueue::getEventMeshLoaded().setEnabled(false);
AsyncQueue::getEventMeshLoaded().setEnabled(true);
Return value
Event reference.
static Event<const char *, int> getEventImageLoaded() const#
event triggered when the image is loaded. You can subscribe to events via connect()  and unsubscribe via disconnect(). You can also use EventConnection  and EventConnections  classes for convenience (see examples below).
See Example
Usage Example
// implement the ImageLoaded event handler
void imageloaded_event_handler(const char * name,  int id)
	Log::message("\Handling ImageLoaded event\n");
EventConnections imageloaded_event_connections;
AsyncQueue::getEventImageLoaded().connect(imageloaded_event_connections, imageloaded_event_handler);
AsyncQueue::getEventImageLoaded().connect(imageloaded_event_connections, [](const char * name,  int id) {
		Log::message("\Handling ImageLoaded event (lambda).\n");
imageloaded_event_connections.disconnectAll();
EventConnection imageloaded_event_connection;
// subscribe to the ImageLoaded event with a handler function keeping the connection
AsyncQueue::getEventImageLoaded().connect(imageloaded_event_connection, imageloaded_event_handler);
imageloaded_event_connection.setEnabled(false);
imageloaded_event_connection.setEnabled(true);
// remove subscription to the ImageLoaded event via the connection
imageloaded_event_connection.disconnect();
class SomeClass
	// A ImageLoaded event handler implemented as a class member
AsyncQueue::getEventImageLoaded().connect(sc->e_connections, sc, &SomeClass::event_handler);
delete sc;
EventConnectionId imageloaded_handler_id;
// subscribe to the ImageLoaded event with a lambda handler function and keeping connection ID
imageloaded_handler_id = AsyncQueue::getEventImageLoaded().connect(e_connections, [](const char * name,  int id) {
AsyncQueue::getEventImageLoaded().disconnect(imageloaded_handler_id);
//   5. Ignoring all ImageLoaded events when necessary
AsyncQueue::getEventImageLoaded().setEnabled(false);
AsyncQueue::getEventImageLoaded().setEnabled(true);
Return value
Event reference.
static Event<const char *, int> getEventFileLoaded() const#
event triggered when the file is loaded. You can subscribe to events via connect()  and unsubscribe via disconnect(). You can also use EventConnection  and EventConnections  classes for convenience (see examples below).
See Example
Usage Example
// implement the FileLoaded event handler
void fileloaded_event_handler(const char * name,  int id)
	Log::message("\Handling FileLoaded event\n");
EventConnections fileloaded_event_connections;
AsyncQueue::getEventFileLoaded().connect(fileloaded_event_connections, fileloaded_event_handler);
AsyncQueue::getEventFileLoaded().connect(fileloaded_event_connections, [](const char * name,  int id) {
		Log::message("\Handling FileLoaded event (lambda).\n");
fileloaded_event_connections.disconnectAll();
EventConnection fileloaded_event_connection;
// subscribe to the FileLoaded event with a handler function keeping the connection
AsyncQueue::getEventFileLoaded().connect(fileloaded_event_connection, fileloaded_event_handler);
fileloaded_event_connection.setEnabled(false);
fileloaded_event_connection.setEnabled(true);
// remove subscription to the FileLoaded event via the connection
fileloaded_event_connection.disconnect();
class SomeClass
	// A FileLoaded event handler implemented as a class member
AsyncQueue::getEventFileLoaded().connect(sc->e_connections, sc, &SomeClass::event_handler);
delete sc;
EventConnectionId fileloaded_handler_id;
// subscribe to the FileLoaded event with a lambda handler function and keeping connection ID
fileloaded_handler_id = AsyncQueue::getEventFileLoaded().connect(e_connections, [](const char * name,  int id) {
AsyncQueue::getEventFileLoaded().disconnect(fileloaded_handler_id);
//   5. Ignoring all FileLoaded events when necessary
AsyncQueue::getEventFileLoaded().setEnabled(false);
AsyncQueue::getEventFileLoaded().setEnabled(true);
Return value
Event reference.
Ptr<Image> getImage ( int id ) #
Returns the image loaded by the specified operation.
This method does not remove the image from the list of loaded ones. If you want the image to be removed from this list right after retrieving it, use the takeImage() method.
Arguments
  • int id - Loading operation identifier (see the loadImage() method).
Return value
Image smart pointer.
Ptr<Mesh> getMesh ( int id ) #
Returns the mesh loaded by the specified operation.
This method does not remove the mesh from the list of loaded ones. If you want the mesh to be removed from this list right after retrieving it, use the takeMesh() method.
Arguments
  • int id - Loading operation identifier (see the loadMesh() method).
Return value
Mesh smart pointer.
Ptr<Node> getNode ( int id ) #
Returns the node loaded by the specified operation. If the node loaded by the specified operation consists of multiple objects, a new dummy object to combine them is created and its smart pointer is returned.
This method does not remove the node from the list of loaded ones. If you want the node to be removed from this list right after retrieving it, use the takeNode() method.
Arguments
  • int id - Loading operation identifier (see the loadNode() method).
Return value
Node smart pointer.
int getNodes ( int id, Vector<Ptr<Node>> & OUT_nodes ) const#
Puts the nodes loaded by the specified operation to the specified array. If the node loaded by the specified operation consists of multiple objects, they are put into the array.
This method does not remove the nodes from the list of loaded ones. If you want the nodes to be removed from this list right after retrieving them, use the takeNodes() method.
Arguments
  • int id - Loading operation identifier.
  • Vector<Ptr<Node>> & OUT_nodes - Array of loaded nodes' smart pointers.
Return value
1 if the operation is successful; otherwise, 0.
int checkFile ( int id ) #
Returns a value indicating if the file is in the loading queue or already loaded.
Arguments
  • int id - Loading operation identifier (see the loadFile() method).
Return value
1 if the file is in the loading queue or already loaded; otherwise, 0.
int checkImage ( int id ) #
Returns a value indicating if the image is in the loading queue or already loaded.
Arguments
Return value
1 if the image is in the loading queue or already loaded; otherwise, 0.
int checkMesh ( int id ) #
Returns a value indicating if the mesh is in the loading queue or already loaded.
Arguments
Return value
1 if the mesh is in the loading queue or already loaded; otherwise, 0.
int checkNode ( int id ) #
Returns a value indicating if the node is in the loading queue or already loaded.
Arguments
Return value
1 if the node is in the loading queue or already loaded; otherwise, 0.
int forceFile ( int id ) #
Forces loading of the file. The specified file will be loaded right after the currently loading file (if any) is processed. All other file system operations are suspended until the forced file is loaded.
The file won't be loaded immediately after calling the method as it can be large.
Arguments
Return value
1 if the file is loaded successfully; otherwise, 0.
int forceImage ( int id ) #
Forces loading of the image. The specified image will be loaded right after the currently loading image (if any) is processed. All other file system operations are suspended until the forced image is loaded.
The image won't be loaded immediately after calling the method as it can be large.
Arguments
Return value
1 if the image is loaded successfully; otherwise, 0.
int forceMesh ( int id ) #
Forces loading of the mesh. The specified mesf will be loaded right after the currently loading mesh (if any) is processed. All other file system operations are suspended until the forced mesh is loaded.
The mesh won't be loaded immediately after calling the method as it can be large.
Arguments
Return value
1 if the mesh is loaded successfully; otherwise, 0.
int forceNode ( int id ) #
Forces loading of the node. The specified node will be loaded right after the currently loading node (if any) is processed. All other file system operations are suspended until the forced node is loaded.
The node won't be loaded immediately after calling the method as it can be large.
Arguments
Return value
1 if the node is loaded successfully; otherwise, 0.
int loadFile ( const char * name, int group = 0, float weight = 0.0f ) #
Loads a given file with the specified group and priority to the thread.
Arguments
  • const char * name - Absolute or relative path to the file (including its name).
  • int group - Priority group. Greater priority means faster loading. The default value is 0.
  • float weight - Weight of the priority inside the group. Greater weight means faster loading inside the same priority group. The default value is 0.0f.
Return value
int loadImage ( const char * name, int group = 0, float weight = 0.0f ) #
Loads a given image file with the specified group and priority to the thread.
Arguments
  • const char * name - Absolute or relative path to the image file (including its name).
Return value
int loadMesh ( const char * name, int group = 0, float weight = 0.0f ) #
Loads a given mesh-file with the specified group and priority to the thread.
Arguments
  • const char * name - Absolute or relative path to the *.mesh file (including its name).
Return value
int loadNode ( const char * name, int group = 0, float weight = 0.0f ) #
Loads a given node-file with the specified group and priority to the thread.
In order to display such asynchronously loaded node, the updateEnabled() method should be called for it from the main thread.
Arguments
  • const char * name - Absolute or relative path to the *.node file (including its name).
Return value
int removeFile ( int id ) #
Removes the given file from the loading queue or from the list of loaded files, if it was already loaded.
If the specified file is currently loading, it will be removed after the loading operation is completed.
Arguments
Return value
1 if the file is successfully removed; otherwise, 0.
int removeImage ( int id ) #
Removes the given image from the loading queue or from the list of loaded images, if it was already loaded.
If the specified image is currently loading, it will be removed after the loading operation is completed.
Arguments
Return value
1 if the image is successfully removed; otherwise, 0.
int removeMesh ( int id ) #
Removes the given mesh from the loading queue or from the list of loaded meshes, if it was already loaded.
If the specified mesh is currently loading, it will be removed after the loading operation is completed.
Arguments
Return value
1 if the mesh is successfully removed; otherwise, 0.
int removeNode ( int id ) #
Removes the given node from the loading queue or from the list of loaded nodes, if it was already loaded.
If the specified node is currently loading, it will be removed after the loading operation is completed. Nodes are removed with all their hierarchy.
Arguments
Return value
1 if the node is removed successfully; otherwise, 0.
Ptr<Image> takeImage ( int id ) #
Returns the image loaded by the specified operation and removes it from the list of loaded images.
Arguments
Return value
Ptr<Mesh> takeMesh ( int id ) #
Returns the mesh loaded by the specified operation and removes it from the list of loaded meshes.
Arguments
Return value
Mesh smart pointer.
Ptr<Node> takeNode ( int id ) #
Returns the node loaded by the specified operation and removes it from the list of loaded nodes.
Arguments
Return value
Node smart pointer.
int takeNodes ( int id, Vector<Ptr<Node>> & OUT_nodes ) const#
Puts the nodes loaded by the specified operation to the specified array and removes them from the list of loaded nodes. If the node loaded by the specified operation consists of multiple objects, they are put into the array.
Arguments
Return value
int loadImageInfo ( const char * name, int group = 0, float weight = 0.0f ) #
Loads file info (size format, etc.) for the specified image, group and priority to the thread.
Arguments
Return value
Last update: 09.10.2024
